Hello,
I was planning on rebuilding my autolite 1100, 1 barrel carb on my 67 mustang. I noticed that when I operate the throttle shaft by hand (under the hood carb is still on car) and squirt gas into the carb it leaks gas out of where the throttle shaft goes into the carb. It does not feel loose but it does leak a few drops of gas.
I don't want to spend the time rebuilding this one if it is shot? What do you think? Also, the car is running rich and stalling out occasionally. Could this leak be my problem? I was going to rebuild the carb so it will hopefully stop this problem. I have checked or replaced everything else...
P.S. I want to buy the new autolite from Pony carbs but there not ready yet and way expensive too!
