Howdy:
Good choice on plugs. You might want to try a set of 45 heat range, especially for summer use. I usually wait til I see them on sale at one of the parts stores. The 46s may be a little hot for all out running. Anyway, you probably won't be able to tell much difference goin' to 20 from 24 initial in performance. Once you get the best advance setting determined, go back and set the low speed idle with your vacuum gauge. Do you have any data on mileage- before and now? How does it compare?
Hi Johnsondawg.Liked the build thread on classicbronchos.Keep up the good work.
