62Ranchero200
Greetings Ford Six Fans,
Could any of you that have upgraded from the OEM 1V to an Autolite 2100 or 2150 2V please post photos of your throttle linkage and fuel line hookup? I have an '80 200, currently with a Holley 1946 1V, that I am planning to upgrade with a CI 1V-2V adapter and an Autolite 2100 (1.02 = 245 CFM). The 200 has a flat (not hex) "large log" head and a throttle cable.
I know that the Autolite 2100 upgrade is also done by machining the intake manifold and using a different 1V-2V adapter, but I'm thinking that the throttle linkage and fuel line hookup should be similar either way, although the profile of the adapters might vary, causing slight differences in the geometry of the linkage and fuel line.
Thank you,
Bob the Builder
Thank you,
Bob the Builder
