78 granada
Well we finally got the 78 Granada fired up and it sounds awesome! So if you can help me out, I have a lifter knock which is not unusual. I have RAU adjustable rockers and hydraulic lifters. Knock is coming from the front and those cylinders SEEM to be adjusted tighter if you go by the remaining threads (dimensionally) on the rockers. I have an instinct to actually loosen the noisy ones but that seems wrong. Can a hydraulic lifter that is too tight knock? Seems like it would be quiet but crack the valve open.
Next question is this: I have a Redline regulator for my Weber carb. Supposedly 3.5 psi max. I have it cranked down all the way and still have less than 3. Gauge is 'new' and it runs great at least in the driveway! Does a stock again 'new' mechanical pump only put out 3 or less psi?
Boy this thing sounds great. Had a good break in for the cam with good rpm until everything was up to temp. Hope that knocking didn't hurt the break in!
What do you all say? I know you've been there.....
