I'M QUITE DISAPOINTED RIGHT NOW.
PURCHASED A 99 RANGER THAT WAS RUN OUT OF OIL. BROUGHT THE ENGINE TO A ENGINE SHOP TO REBUILD. 30 OVER, NEW PISTONS, TWO RECON RODS ECT.
LAST WEEKED INSTALLED THE ENGINE IN THE TRUCK TEACHING MY SON WITH EACH STEP. WHEN COMPLETED SHE STARTED RIGHT OFF AND RAN GREAT, AND THEN A TRICKLE OF OIL UNDER THE TRUCK. SEEMED TO BE A LEAKY VALVE COVER SO I PULLED IT OFF AND RECHECKED AGAIN. STILL SAME PROBLEM THEM WENT THROUGH THE PROCESS AGAIN. (DUMB ) THEN LOOKING EVEN CLOSER SEEMED TO BE RUNNING OUT OF THE BELL HOUSING RIGHT SIDE ABOUT A DRIP PER SECOND.
I PULLED A COUPLE OF THE COVER BOLTS AND COULD SEE THE DRIVERS SIDE LEAKING A BIT. I KNOW YOU MAY BE THINKING WHAT I THOUGHT, REAR MAIN. I HAVE PROBABLY DONE A DOZEN ENGINES OVER THE YEARS BUT NEVER HAD ANY MAJOR PROBLEMS. SO WHAT ELSE COULD I DO BUT PULL THE ENGINE AGAIN.
WHEN IT WAS ON THE HOIST WE BEGAN LOOKING AT THE AREA THAT WAS WET WITH OIL ON THE BACK OF THE ENGINE, I COULDN'T BE SURE WHERE THE LEAK HAD COME FROM. THE SEAL LOOKED GOOD. I HOOKED UP A 1/2" DRILL TO THE FRONT OF THE CRANK AND TURNED THE ENGINE OVER FOR A MINUTE, ONE OF THE ALLEN HEAD SET SCREWS FOR THE OIL PASSAGES THAT ARE SOMETIMES REMOVED WHEN CLEANING AN ENGINE WAS SEEPING OUT OIL.
THE PLUG HAD BEEN WRAPED IN TEFLON TAPE WHEN THE ENGINE BUILDER HAD COMPLETED HIS WORK. IT SEEMED TO BE A LITTLE LOOSE. I COULD TURN IT ABOUT 1/4 TURN.
ALTHOUGH I WAS A LITTLE MAD I PULLED THE PLUG RE-WRAPPED IT IN TEFLON AND RE INSTALLED IT. "AT LEAST THIS IS SOMETHING WE ARE ABLE TO DOWITHOUT HAVING TO PAY SOMEONE ELSE" I TOLD MY SON. WE RAN IT WITH THE DRILL FOR ABOUT FIVE MINUTES AND DID NOT SEE ANY MORE LEAKING. O.K.
I REINSTALLED THE ENGINGE AGAIN TIED IT ALL UP RAN THE ENGINE FOR ABOUT AN HOUR, ALL LOOKED GOOD, EVEN PUT THE HOOD BACK ON HAPPY WITH OUR WORK. TELL MY SON "SOMETIME YOU NEED TO OVERCOME OBSTACLES". A FEW MINUTES LATER, DRIP, DRIP. AS THE OIL HEATS UP IT GETS THINNER.
TALKED WITH MY FATHER THE OLD MECHANIC, NOW I'M CONCERNED ABOUT POSSIBLY A SMALL CRACK IN THE PLUG AREA.
ANY SUGGESTIONS?
ANY SUGGESTIONS?
