we got my buddies freshly rebuilt 250 in his 71 2dr the other day. we had it ready to run and tried to start it. the timing was a little off so it didn't start in the 3-4 minutes we were playing with the ignition timing. its probably better that it didn't though since we noticed a deluge of oil draining down the divider plate that goes between the engine and tranny (what is that plate called anyway?). we both almost cried when we thought we'd have to pull the crank and replace the rear main seal. when we got the motor back out of the car though we found something very peculiar. what purpose does an oil port have on the back of the motor if it is covered up by a backing plate and a bell housing. we found a threaded hole in the back of the motor. we thought the hole had a back/bottom to it so we didn't put a bolt or plug in it. why would we need to put a plug in a hole that doesn't go anywhere? as it turns out, the hole DOES goes all the way through into the crank case. what the f@#k? why is there a hole like that there? why? why? why? why? well my buddy and i both feel like complete retartds. at least we didn't have to pull the oilpan and crank and timing gear cover and rod caps and main caps and our hair out and... you get the point i'm sure. the motor is back in the car on the mounts again. this time the hole is plugged. lets just hope the rear main seal isn't leaking too. i dont think it is. keep your fingers crossed for us anyway.
signed,
me
signed,
me
