64 inboard":2wzsbt2p said:James,
..... Talking about cooling, I cant get this to run any temp. Its supposed to have a 140 tstat, I installed a 160. My gauge will occasionally run up at idle, but drops to the 100 range while running. We are wondering if the raw water pump has too much pressure and is actually forcing the tstat's spring open so it cant build up heat? I may try to install a ball valve in the "out" line of the pump, so I can throttle the supply down a little? As for the air lock, I drill a 1/8" hole in the t.stat.
Get your self one of these thermostats water pressure won't effect it.
http://www.jegs.com/i/Mr.+Gasket/720/4363/10002/-1
I just showed you jegs so you could see it. Regular parts stores sometimes have them.
I have no idea how they have on of these sixs plumbed for cooling, but
I have also heard of people rerouting the water from the pump across the exh first to warm it up a bit??, although I am wondering what thermal shock is going to there. That way the water isn't 60-80F going into the block and head. Or a even better idea might be to route it to the sides of the oil pan first?? (wraping the pan with pipe or hose to do the same thing to a lesser extent.)
