how much boost can be run with stock compression and cast pistons for a 200 daily driver
RacinNdrummin":1wz1f4gn said:Sort of....
What it comes down to is how much air your engine can flow...
With the small turbo, the 50cfm @ 10psi may work just fine, and do it lower in the RPM range. With the bigger turbo that pushes 50cfm @1psi, your engine is going to have to spin higher to take advantage of the bigger turbo, because 10psi is 10psi, no matter what, and if your engine can only flow 50cfm at 10psi, thats all your going to get.
ryan11":1tkjchk7 said:RacinNdrummin":1tkjchk7 said:Sort of....
yes, but i have seen this same ? many times with new commers to boost, and i try to tell them what i wrote 1st, so they can start searching, then after some reseach they will start asking ?'s about turbo maps.
ryan11":16nis6e6 said:RacinNdrummin":16nis6e6 said:Sort of....
ryan11":31mrqz32 said:boost psi is different in different turbos,,in laymans terms, a small turbo at 10 psi might = a big turbo turbo at 1psi
lame example:: small turbo at 10 psi pushes 50cfm big turbo a 1 psi pushes 50 cfm.
yes detonation and timing kill motors, but there are limits to things as you already know, i can have a standalone and have a perfect tune,but cetain parts can only take so much.rbohm":2m4ed3aw said:8) ok, to answer the original question, it isnt boost pressure, to a point, that kills pistons, it is detonation. as long as you stay away from detonation, the stock pistons will handle 10psi without problems. another thing that kills engines is rpm. stay under 6000 while boosting the engine, and again 10psi is not a problem.
now as for boost pressure, it in reality is a measure of back pressure. take for instance a stock small block ford with stock heads, and boost it with 10psi, and you get about 350 or so hp. now take that same engine and drop on a set of aftermarket heads using the same setup, turbo, supercharger it doesnt matter, and at the same rpms the boost pressure indicated actually drops, but hp goes up. the reason is that the engine is breathing better, thus more airflow gets through with less pressure.
so before you boost an engine, optimize the intake and exhaust tracts as best you can, then boost the engine.
ryan11":2lfoepu5 said:yes there are other things that do factor in,, but no matter how you cut it a
ihi vj-11 (small tubro came on mazda 2.2 sohc) at 10 psi will never make as much power as a holset hx-35 (bigger turbo came on mostly dodge desiels) at 10 psi, no matter what motor it is on, so 10 psi is not same, so you can not go around saying my straight 6 can take 20psi,, cause 20psi on this turbo is not 20 psi on that turbo.
o.k. fair enough, im not trying to misinform anyone or try to start and war with you or anyone..JGTurbo":36u18kz1 said:ryan11":36u18kz1 said:yes there are other things that do factor in,, but no matter how you cut it a
Now I'll say you're wrong. 10psi in the manifold is 10 psi in the manifold regardless of what puts it there (all other things being equal). The only reason a vj-11 might not make the same power as a hx-35 is because it cannot make 10psi at the mass flow rate required to match the hx-35. An overly small turbo will over-speed and self destruct before it makes 10 psi on a straight 6. An overly large turbo might never spin fast enough to make 10 psi on a straight six. But all turbos that can make 10 psi manifold pressure over a similar rpm range with similar efficiencies will make the same power. I'm only arguing this because saying that the same manifold pressure from a different turbo will make different power (all else being equal) is absurd. Just don't want ideas like that to spread very far.
