1981 3.3 pushrods, non adjustable hydraulic lifters. Rockers with cups
1963 170 pushrods, adjustable, used for hydraulic lifter 1967 200
Same length, but the US versions have ball ends on both, and the Aussie versions have cups on the top and rockers with balls. The last T, B and X code engines (from 1978, 1980 and 1983 respectively) onward had the lowest rocker cover, and windage trays on the them might come in contact with high lift cams and adjustable valve gear.
If your changing over to adjustable valve gear, note that the pushrods differ.
