It seems the bolt for the alternator bracket that goes thru the water pump broke off for whatever reason. Of course it couldn't break off with any sticking out to get a hold of, it had to break off into the block. Now to make matters worse the easy out broke off in the hole. Now I'm really screwed. Has anyone had this problem and how did you fix it??
Has anyone heated the block to remove a bolt and not had it crack or caused any other damage???
:x
