Werby Ford provided me with cam specs since I did not get a card. His specs are noted above in this thread. However my readings are as follows: 3 degree after tdc .050 beginning lift and 38 after bdc at the decline .050 reading. That gives me a 215 duration. This is one degree duration off the specs Werby Ford provided. I have come up with this reading three times in a row. The 3 degree after tdc is 6 degrees more advanced then Werby Ford specs. I reached tdc following the instructions for my degreeing kit noted below.
"Finding Top Dead Center (TDC):
1. Rotate the crankshaft until you get number one piston in approximate TDC position. Next, adjust your pointer to the
zero TDC position on the degree wheel.
2. It is essential at this point that you have some means of rotating the crank that will not interfere with the degree
wheel. The crank can be rotated from either the front or the flywheel end. The greater the leverage, the smoother
you can rotate the crank for timing checks. (Do not use the starter for turning the engine while degreeing).
3. Now that the Degree Wheel has been set at approximate TDC, and a means
for turning the crank provided, you’re ready to install and set the piston stop.
Turn the crankshaft to lower the piston enough in the cylinder to move the
degree wheel 15-20 degrees. Install the piston stop so that it contacts the
piston. (Figure 5) Turn the engine in the same direction until the piston
comes back up and touches the piston stop. Make a note of what degree the
pointer is on the degree wheel. Turn the engine in the opposite direction until
the piston comes back up and touches the piston stop. Make a note of what
degree the pointer is on the degree wheel. Add these two numbers together
then divide them in half. Example: Let’s say that the stop points are 16° in one
direction and 20° in the opposite direction. The total would be 36 degrees. This
figure divided in half would be 18 degrees. Therefore 18 degrees from either of
your stop points is true top dead center. Now either move the pointer to align with
the 18 degree mark on the degree wheel, or carefully loosen the degree wheel FIGURE 5
(without disturbing the position of the crankshaft) and move the degree wheel to the
18 degree mark, making sure that the piston is still against the stop. Now turn the engine in the opposite direction
until the piston comes back up and touches the stop. The pointer should be aligned with the 18 degree mark on the
other side of the TDC mark. If this is correct, then you have found true top dead center. It is best to repeat this to
make sure that nothing has moved. If you didn’t get 18°, as per the example, you will need to repeat the procedure
until you get the same amount of degrees on both sides of TDC. Remove your piston stop and you are ready to
properly degree your cam.
What should I being doing next?
