I'd stick with what you have. It's very easy to screw up a propane engine with too much duration. They don't like it, and the mixture can go out the exhast if its not set up right. Impco carbs and long duration don't go together well on heavy Falcons, but on a Cortina, it may be guite permissable. The GRA carb is better in this repect than the Impco, but the 90 degree bend before the carby manifold is a bad idea. No way to change it!
The EFI manifold is worse at being able to dial in advance, due to the un-used mixture in the long intake ducts causing backfire on over-run. Advance it on the dyno, its fine, lift off on overrun through a corner or coasting to the lights, and its as rough and poppy as an early RX-7. SO THE DYNO GUYS TEND TO BACK OFF THE INITIAL TIMEING, LOOSEING POWER BUT GAINING SAFETY.
The gearing and everything needs to be just right. A few degrees too much can soften the low-end grunt a heck of a lot.
From
how much horsepower to you have??:-
			I don't know what I've got, but is sure more than the 115 hp at the rear wheels I got in November 1998 when my 1984 Alloy head 4.1 XE Falcon was last dyno'd. Thats around 150 ponies at the flywheel.
Spec then was 500 cfm Holley #2300 4412 carb on adaptor to stock 34 ADM Weber manifold, no extractors, LPG Impco CA 300 A1 348 cfm propane carb with 2.5 inch adaptor to sandwhich the two together. Did 23 Imperial miles to the gallon after that on the open road, a 20% improvement on the old dual fuel figures. Motor is +30 thou over with ACL shallow top pistons. Gear box is silly old BW 35 auto with 2.77:1 diff and it weighs 3165 pounds all up with full tank and no passengers.
Since then, it's had major intake work, extractors and K&N filter. Now it's much nicer around town with tyre smoking torque, and revs freely out to 5300 rpm with the stock economy cam.
Just to add:-My Falcon got the ~256 (at lash) duration Heatseaker  (ex USA) grind, and I used the 2.77:1 gears and Borg Warner auto. Lp gas, and changed to the 432 cfm of Impco CA 300 carb with 500 Holley throttle body (two 43 mm throttles). Stock XE valve sizes, just a relieved intake, 12 mm thick port spacers to stop reversion, and, eventually, a NZ-made 'Heateaker' (no relation to the US brand) header with the stock XE tailpipe (47 mm internal)
I have to say the diff wasn't much of an issue. I was looking at 3.23:1 gears, but from all the calcs I did, I don't think stand-off grunt would have improved that much.
The engine produced bag-loads of torque, far in excess of any LP gas 302C or cammed petrol 351C 2V from idle to about 2700 rpm. The dynoed figure was 194 lb-ft at 2600 rpm, which is about 350 Nm installed from my calcs. Maximum power wasn't noted. But in the old days it was abot 77 hp with the stock Weber ADM and Landi-Hartog Mixer. After getting the better LPG carb, it went up to 115 rwhp, or around 153 hp installed. Then I added headers which are normally an 18% power boost on a stoker, but less when you have a restrictuve exhast like my old hump. I felt there was about 174hp, or 131 rwhp based on my (single) 16 second flat quarter mile time two-up.
See this for the information
http://fordsix.com/forum/viewtopic.php?t=1420&highlight=
