sivadmatt99
Active member
Ok here we go. I bought a 63 Falcon about 3 years ago. The previous owner informed me that the engine has been rebuilt and had a mild cam in it. Today I had the valve cover off and noticed it had hydraulic lifters. Block is a C3DE. Which leads me to believe that it is not drilled for hydraulic lifters and should have a solid lifter cam. So can i run solid lifters on a comp cams lift.425 duration .050 206 cam. I would much rather buy new lifters
Thanks matt
Thanks matt
