carb adapter question
It says
Carburetor Manufacturer Holley
Carburetor Model 2300
Carburetor Flange (application) Holley 2-barrel
Carburetor Bolt Pattern 4-bolt (5 1/8 in. x 3 1/2 in.)
Manifold Mounting Flange Small 1-barrel
Manifold Bolt Pattern 2-bolt (2 5/8 in.)
the adapter fits the smaller 2-5/8" pattern opening, so that would be the one you have/need.
Download the Transdapt brochure and read the specs of the adapter.
Adapters
I have a large hole manifold (from '78) so mine is the Chevy one. I read and measured using this and figured out that one would work with slight modification. Also an Autolite 2100/2150 is close to the specs, I had to drill out the mount holes on the carb slightly to get it to work.
