Hey all. I finally got around to making the carb changes that William (and others) have suggested...
dropped my main jets even further. Went from the original 73's running really rich, to 71's last week which were still rich, to 68's tonight. Seem better (upper end of STOICH on the gauge at idle).
changed to the orange pump cam at #2 position
changed to the 30CC pump (from 50cc original). I think i got the pump lever adjustment right. I don't have a feeler gauge, but I just set it so that there is no play between the spring screw and the pump lever at idle position. Sound right?
I left the 8.5 PV in there, but I'm getting a little lean shot right from GO so I may need to bump it up right? I also do get a slight hesitation if I'm cruising at like 25mph and I stomp on it. What do you think? Need to up the jets maybe to 70's? different PV?
I also added a fuel pressure gauge in line. I'm only getting a hair more that 3PSI out of the stock pump.
I've read my Holley really wants more like 6, no? Maybe need to invest in an electric pump and regulator setup...what do you think?
I haven't changed the shooters at all. Should I tinker with them? the fuel shot that comes out doesn't seem very atomized...pretty solid shot of fuel. Don't I want it more of a spray?
I checked out a copy of Powertuning Holley Carbs...best read in a while. If you have a Holley and want to tinker and tune it, go find this book. It's the bible of Holleys.
Thanks all.
Thanks all.
