Drives a 5
New member with an 82 fairmont 200ci w/ 1946 & c5 auto. This is my first carbed car, was wondering if anyone could give me a little advice.
When I got the car a while ago, it needed a few things... it pinged under acceleration, 2 of the spark plugs were completely loose, dieseled most times when I turned it off, would die at stoplights, etc.
To make a long story short, I gave it a new cap, rotor, plugs, wires, air filter, set the timing, and adjusted the idle down. This fixed most things...
However it now has a kind of hesitation when starting off when I get on it. If I go gradually it accelerates fine and smooth. If I mash it it will die. If I hit it relatively hard, it will hesitate, then start to pick up speed and will be fine throughout the upper rpm ranges after that.
So anyone who could give me any info, ideas, whatever, it would be much appreciated!
