granadastraightsix
my first plans for my 250 was to get the dui duraspark II kit and headers. am i gonna need to upgrade to a 2v intake and carb before i do this or will i get away with it for a year???
Leave the carb for now ( unless its Bad ( can't be rebuilt ,Broken etc ) , The Ignition is good to 7000 if set up correctly ( proper curve ) the DUI is not Cost Effective Espcially since you already have a Duraspark , if you want to up grade add a MSD 6AL and a Blaster III Coil ( still way less than a DUI ) I am assuming your Granada is an Automatic , and if so adding a Higher stall converter will give you the most 0-60 improvement you can make ( nice thing about a 250 is it uses the same converters as the V-8 302 family ) 250-300 dollar range will be all it costs , when choosing go up aprox 500 more stall than for a 302 ( an 11 inch rated at 2600-2800 ) , Then gears , Then a Camgranadastraightrape":1n23hrwo said:my first plans for my 250 was to get the dui duraspark II kit and headers. am i gonna need to upgrade to a 2v intake and carb before i do this or will i get away with it for a year???
