Ok, I had problems before and posted about it and got some fixes from it. I put the 350 back on the old engine which is still in the car with the clifford adapter but this time I have a 7.5 PV, the correct bowl gasket with a hole for the Accel pump..(the one I had did'nt have one so I made one but it leaked back into the bowl
) It has the 50 cc diaphram and stock 280 nozzles. I think anyways.
Well, the problems I had before were it would bog out if I so much as tried anything more than 1/3 throttle at low rpms or off the line. It would just die out like fuel was cut off or it was flooded very rapidly. So I tried different jet sizes and power valves with no change in problem. Also noticed was the fact the air fuel screws have to be all the way in for it to run smooth. Even one turn out roughened the idle. Thats a problem as well.
Ok, well now that the correct PV is in, and the bogging out was due to lack of accel pump pumpage and thats fixed..I can stomp it now and she goes but...I still have to have the air fuel screws all the way in. Is this a rich condition? Oh, and there's this kind of whistle coming from the carb almost like air being sucked in a tiny hole..But I can't find any! I only hear it when accelerating. The fact that the screws have to be all the way in is just like what my lawn tractor was doing..come to find out that the carb had a huge crack in it. I fixed that and now it runs right with the air fuel about 3 turns out and it will run rough in both directions instead of one which means the mixture adjust is working.
Why I mention my lawn tractor is that it sounds like theres a leak in the holley but I can't find any. The bowl vent tube that sticks straight up, it has vacuum on it. It increases with engine speed and if I cover it the engine shuts off. Is that normal? Do I need to down size my jets to get correct air fuel mix?
