Jeff_Stafford
Hi, I have a 1961 Ford Falcon Futura with a straight six. I think it may be a 170, but it is not the original engine. I know on a SBF the casting numbers to identify are located underneath the starter area...I assume the same holds true for the 144/170/200 engine. My block has casting numbers on the drivers side, which indicate a 1963 Ford Falcon block. Additionally I have 3 freeze plugs (that I can see anyway), but I understand that some early 200ci motors also had 3 freeze plugs and 4 main bearings. If the casting n umbers are under the starter, why would the same casting numbers be on the driver side of the block? My drivers side casting numbers are: C3DE-6015 E. Thanks...great looking site! BTW, the cylinder head has a casting number of C6DE-6090-B.
