I put a new alt. on over the weekend. I'm pretty sure its hooked up right but it doesn't seem to charge very well. Belt is tight and it is hooked up according to a diagram I pulled off this sight. Last night I was running heater fan, high beams and wipers. Everything ran fine but it didn't want to start after a short shut down. I would think it would have to be charging to keep up with the load last night but it doesn't seem to be charging the battery. I did not replace the voltage regulator. Should I have and could that be the problem? All this is on my 74 Bronco. Thanks
Steve
Steve
