CHOKE HEAT TUBE O.D. SIZE RBS CARB
BCOWANWHEELS
Whats the outside diameter of the heat tube on a 250 engine with a carter rbs carb please ? also isn't the tube to carb connector a standard fitting with ferrel inside ?
THANKS
BOB
the Help section of the big box stores…. on a green/red/white card hanging up, isle 6 I think…
(lill brass nut, white asbestose sox, alu tube…)
OR
several 'stang specialty warehouses on the net.
(this latter is listed cuz U say U don't live in a high mrkt area & may want the interweb).
TRADE YA:
Who has the oil pump hex drive shaft to chuck in your driver to pre lube (pump up) on 1st start up?
chad":3l3f7ftj said:
TRADE YA:
I just use a 5/16 socket nut driver and a long extension chucked in the drill
They are Tubing threads and yes you are correct it's a compression fitting and Ferrell. Good luck :nod:
RC -
i saw that earlier - does it fit in & stay thru the operation?
I'm all ways 4 cheeper!
chad":ess35mee said:
RC -
I use the "screw bit type" nut driver, with the hex drive, and a "screw gun" hex extension. they click together solid, and it says together fine (never made it work with a normal socket, they were all to big OD)
I'm using the shaft out of my old distributor. I have to admit it took a couple beers to get everything disassembled and pressed off the shaft!
RichCreations":svl8qwq1 said:
chad":svl8qwq1 said:
TRADE YA:
Be careful with this type of method ,you can gouge up the distributor bearing surface in the block ! Ask me how I know.
"…this type of method ,you can gouge up…"
I'll soon B upon this stage of the ssembly process. Got nother suggestion?
I'm gunna pack in a lill assembly grease, then wanna spin the pump to draw in/distrubute the special crancase break-in oil, & run it 20 min @ 2,ooo rpm.
Well if you want to be really safe, there are the air tank pre-oilers that are fairly cheap. On Air-cooled VWs, I use a small gear pump plumbed into the oil pressure port and run it with a drill, and pump until the sump is full.
BCOWANWHEELS":3tv5v9jt said:
guys, please start your own thread…............
Sorry, gotcha.
My fault.
(kinda goes that way here, as apposed to some sites, but apologies).
Please pardon me.
Happy Holiday
(look to the net 4 Obama's Hiroshima speech if you've not seen/heard it).
