Resurrecting this thread because I want to install a clutch fan. I may have to consider electric, but clutch fan is my preference to try first.
If there is anyone running a clutch fan with a 200 I've got a couple questions or concerns that need clarification...
It was my impression that on a clutch fan the leading/front edges of the fan sit almost as far forward as the face of the clutch. Anyone know if that's right? (ie is the surface where the clutch mounts to the blade recessed from the blade tips/front edges?)
I'm looking at a flex-a-lite 15" fan currently, and wondering if a 17" could fit? My current fan is the 6 blade fixed and best I can tell it measures about 15"...it looks like 16" would be okay, but 17" looks like it could be too close. AFAIK 289's or BB used a 17", but not sure it would fit or if it's possilble for the fan to be 'too large' on a stock dimension 200 radiator (ie outer fan diameter larger than radiator width...bad?).
If anyone running any style clutch fan on a 200 could please give me an approximate measure of the overall length added to the snout of the engine...like an approximate measure from the face of the water pump pulley (fan mounting surace) to the face of the clutch at the radiator)???...it would be greatly appreciated!
I have a little less than 3" of space currently between these two surfaces (pulley face and radiator)...not sure if I can get a clutch fan in that short of a space?
I prefer to look into the clutch fan intially for the more stock look as well as my preference to less electrical dependence. My main goal is to stop some of the parasitic loss on hp, but also to balance my current excess cooling capacity. With a newer aluminum radiator, recovery tank and 195* stat (which seems to have done fine during the past summer)...she won't stay warm enough when it's 50* or less here in Texas...and that's even with the heater core currently bypassed
Thanks in advance for any assistance!
