And a bouble shot of crank differences verses timing chain and gear matters.
Its all a little bit too simple! You've got any number of choices. 302 timing chain reversed? Easy!
The I6 has the Cleveland style shoulder, which needs to be cut back on Windsors to fit. from 1987 to 2007, all the Windsor Cleveland race blocks in NASCAR had to have the crank tunrned down to fit the Windsor timing gear, so its easy to machine back. The V8 cranks vary a hughe amount, 1.75 for aftermarkt, 1.370 for some SBF's, but its still a nominal 1-3/8" crank spigot.
The difference between lopping off 127 thou and 50 thou? Just the extra time! Its just too simple!
http://vb.foureyedpride.com/showthread. ... r%29/page6
Like it was made for it.
Well, actually it was. That crank gear had to be cut .300, and the snout of the crank turned down an additional .050.
A keen eye here will notice a full length crank keyway that goes completely under that crank gear to the front of the journal.
For the gear drive, its Diecrest Engineering.
Same deal, but less machining. Easier to make a gear drive off an Aussie 200/250, than a US SBF timing chain reversed.
Just
too simple to machine a crank part down to fit a commerically available sprocket part. Its around, it works. Its simple to adapt. Anything else is just bull pucky. 1.375-1370" vs 1.248" on the crank shoulder is easy to machine down. Or the internal part can be broached up 1/8". Choice is yours.
viewtopic.php?t=56560
balldrick":371c8xw9 said:
Well got my bottom end together today. Went pretty well, had a problem with a bottom oil ring it bent and i noticed a rub mark when i turned the motor over. (The one thing ive learnt is dont by cheap tools).Heres a couple pics.200 rods with 4.6l rover stroker pistons.
Diecrest eng. geardrive.
http://www.diecrest.com.au/contact_us.shtml
JackFish":371c8xw9 said:
So tell us about the gear drive...
Gday JackFish, Its from a company here in Aus called Diecrest Enginering it was advertized to fit the 250 crossflow but as you can see it fits the Aus 250 pre-crossflow as well. This one is adjustable thay also make a non-adjustable a bit cheaper. It seems well made and the only mod needed is to file a slot in timeing cover. I dont know if they will fit the American 250?
