65-coupe
Has any one every used this before? Would it be better then a chain?
http://www.summitracing.com/parts/cca-3 ... /make/ford
JackFish":1gdwwt2j said:Those are for a 300.
cr_bobcat":33uxof4j said:Just looked at the link and it does say "Gear Set Ford 6 Cyl. 240-300 1965-91 Steel Gear"
xctasy":1tu5gkcn said:If you have a custom sprocket made, or turn down the crank snout, the Aussie Ridgecrest 1971-1992 3.3 and 4.1 litre Gear drive can be made to suit.
I'm now fairly certain the crank to cam spacing on the US and Aussie 250's are the same. The US block is heaftier, and the crank has a differertnt thrus bearing and snout, but all the other critical dimensions are the same.
See forum member Baldrick's supercharged CI headed 250 Falcon. Aussie Speed might be able to supply one if you talk with them.
Like it was made for it.
Well, actually it was. That crank gear had to be cut .300, and the snout of the crank turned down an additional .050.
A keen eye here will notice a full length crank keyway that goes completely under that crank gear to the front of the journal.
balldrick":371c8xw9 said:Well got my bottom end together today. Went pretty well, had a problem with a bottom oil ring it bent and i noticed a rub mark when i turned the motor over. (The one thing ive learnt is dont by cheap tools).Heres a couple pics.200 rods with 4.6l rover stroker pistons.
Diecrest eng. geardrive.
balldrick":371c8xw9 said:Gday JackFish, Its from a company here in Aus called Diecrest Enginering it was advertized to fit the 250 crossflow but as you can see it fits the Aus 250 pre-crossflow as well. This one is adjustable thay also make a non-adjustable a bit cheaper. It seems well made and the only mod needed is to file a slot in timeing cover. I dont know if they will fit the American 250?JackFish":371c8xw9 said:So tell us about the gear drive...
