Ok, got a good question for the group.
Currently I have a 5 blade fan that flexes a bit. I can still hear it which means it is making quite a bit of drag on the engine. Has anyone tried an electric fan setup. I tried a few years back, but the motor of the fan had to be offset due to hitting the water pump pulley bolt heads. I gave up and found the 5 blade at a swap meet.
I thought maybe 2 small ones would work as well. You could set up one to run full time and the other to run only when needed.
Any suggestions? Just trying to save a bit of power where possible.
Thanks,
Jason
Thanks,
Jason
