65 Mustang
Hello all,
After much talk, I'm going to be bringing my 200 ci cylinder head to the machine shop next week. After speaking with machinist the following work will be done:
1.) cleaned and rebuilt
2.) 3 angle valve job
3.) backcut on intake valve
4.) hardened seats installed
5.) head milled by 0.030 to compensate for head gasket thickness
I plan to reuse all stock items (springs, valves, etc..) on the cylinder head unless I'm told by machinist they need replacing. Debating having the intake opened to 1.75". Not sure, though. Thought about a carb upgrade, but plan on staying with the stock autolite 1100. I was quoted $599 for work. Hope that sounds reasonable. Thought I'd put this out here to get any feedback. Anything I'm leaving out that I should mention to the machinist? Simply looking to get my 200 ci back to stock level performance. My main concern is cylinder compression. I'm running about 120 psi on all cylinders. Stock should be 175 or so. Hopefully the cylinder head work, the addition of an adjustable rocker arm assembly and a proper tuning will do the trick. Thanks in advance for any input.
