Alabama65stang
After two years of rough idle, low vacuum, poor gas mileage, and oil consumption, I have pulled the head and bought the tools to degree the cam. Upon checking my existing setup, I find the cam is at 96 degrees. CompCams recommends 106 for this cam. Is it very unusual for one to be this far out with a stock gear set? The gear set was from NAPA with the engine rebuild kit. I've now got the adjustable set and plan to install it with the cam at 104 degrees (only 2 degrees advanced, right??) What do you think I can expect as far as the performance issues listed above? Is there any way the cam being advanced this far could affect blow-by and cause my oil consupmtion problems? (don't want to pull those pistons if I don't have to) Any input would be appreciated!!!
