ssm200":2r3z65pc said:I finally went back to work on the car today and things are looking a lot better. I went through all the tuning procedures and made many recommended adjustments. I bought a dial indicator and degree wheel, though i haven't gotten that far yet. It's running good and has steady acceleration through the rev range. It does hesitate a tad right off idle, but i'm pretty sure i can work that out pretty easily with a little more time tuning. I'll be pulling the valve cover next to shim the rocker assembly and check the cam timing. I am planning on fixing the cam timing if it is messed up and i have a couple questions that i am having trouble finding answers to.
1. As I mentioned to you in my last post adjusting the Accelerator pump shot timing and or its duration should take care of your hesitation. If you can post a picture of your acc. Pump linkage settings that you have right now and with a detailed description of how the car is acting then should be able to guide you in which way to adjust it. It should be fairly easy and quick to dial that pump shot in.
I understand how to find TDC with a piston stop and the degree wheel. I understand how to use the dial indicator to find the top of the lobe center of the first intake valve. I don't know what to compare the results to. Should the intake valve be fully open at a standard point before/after TDC or am i missing critical information about my cam?
2. You will need to have your cam card or at least the cams brand name and its number to look up its specs, then we can go from there.
Also, What parts could i possibly need for degreeing in the cam? And, what are my odds of success degreeing in this cam without removing the radiator? It seems like it will be a good idea to remove the fan, but i think i can get the rest without taking the radiator out. or is this more of a pain in the rear than just pulling the radiator?
3. Besides the degree wheel and dial indicator, all you need is a homemade timing pointer to read the degrees (wire coat hanger or better), and some basic hand tools i.e. Socket and ratchet to turn the engines crankshaft. Turning the engine in one direction to be most accurate for your readings unless the timing chain is near new condistion. For the purposes of just checking were the cam timing is set you probally don't need to pull the radiator however when and if you want to set it to a different cam position you will need too.
Thanks for all the help and for keeping me positive. It's easy to give up when it seems like it's all up hill.
ssm200":1tymi2j7 said:Sorry it's taken me a bit to make any progress. I have the valve cover off and rocker assembly removed. TDC on the crank pulley is dead on, confirmed using a degree wheel and a piston stop. I hollowed out an old spark plug and ran a big bolt through and welded it in place. Thanks for the tip, that worked perfectly. Next i used the dial indicator i got to find that max lift of the first intake valve comes in at 107.5*. I don't have the spec sheet on the cam, can't seem to find it online. I did, however find on the CI tech page that it should be 110*. It seems like 2.5* is significant, advice would be greatly appreciated. If i end up pulling the timing cover, i will certainly be putting a better cam in.
I also plan on shimming the rocker assembly as described. The washers i got are pretty thick, probably 1/16". Is this too much? There wasn't a great selection of washers fitting my requirements. I really think this will help the uneven compression.
Thanks,
Steve
ssm200":6opwv8kd said:This is from Larry at Clifford Performance:
Lift Intake 444 exhaust 444
Duration 264 intake 264 exhaust
Open 22 Intake close 62 exhaust
close 62 intake close 22 exhaust
Exhaust opend 33 bdc intake opens -7
Exhaust closes -7 Intake 33
110 lobe centers.
Thank you
Larry 6=8
This doesn't tell me what the cam should be dialed in at. He said that i should just line up the dots on the timing gears...I know that is what i did, but that put me at 107.5 degree lobe centers. Should i leave the cam alone until i rebuild the entire motor in a few years or is this worth the trouble of correcting now? also, does anyone know where i can get a timing set that will make it easier to make a small adjustment like this? I know i've seen crank sprockets with multiple slots for the woodruff key.
After i hear a few opinions, i'll probably be putting it back together with the washers under the rocker stands and continue testing and tuning.
cr_bobcat":3p7whnya said:Maybe I missed something. Did you get a Clifford cam through CI, or was it a Clay Smith? I didn't realize that CI sold any Clifford components.
MustangSix":3p7whnya said:...
I'd relook the lifter preload again. On a stock engine the non-adjustable rockers are designed to preload the lifters by .050 to .070", approximately. Taking another .050 out of the head without shortening the pushrod might put you very close to max preload on those lifters. It might not even be completely apparent on a compression test since you'll get the effect of the full oil pressure when running. Rocker shims are the easiest way to fix it. You can test by just temporarily sticking some fender washers under the stands.
Also, I tried to find it in your posts, but didn't see if the vacuum was disconnected when timing? I would also try operating the engine without vacuum advance for now just to remove one operating variable. Just let the centrifugal handle the advance. Later, when you get it running, plug the vacuum back in.
Frustrating, I know, but all these things are solvable. Good luck.
chad":3p7whnya said:If he wound up at 107.5* doesn't that mean he should advance 2.5* on the TS to get to what's on the card (110LC)?
Now he's got the "card" (by phone to Larry) can some 1 direct him to some instructions (I wanna look over his shoulder so I C it again)?
There's echo's on-line vid (but he's so good at it he goes kinda fast) any book or written pathway thru this?
ssm200":xmfbrax2 said:The washers are right around 0.065 and the rockers don't touch the valves when they are closed. with these washers installed and the rocker assembly torqued, i can fit a 0.025 feeler gauge between the valve and the rocker. I have non-adjustable rockers, hydraulic lifters and hydraulic cam. I used bronze bearings and they are the thinnest washers i can find that have appropriate measurements.
1. Should the rockers have pressure on the valves in a static state?
2. Is this information an indication that the machinist that did the head work possibly did not mill the head as i requested? If he did mill the head to suit a 200 rather than the 250 it came from, 0.065 washers should be damn near perfect. This would mean my combustion chambers are far too large for this motor. Could that be why it isn't responding to the upgrades and modifications like i'm expecting?
If it does have too large of combustion chambers, the decreased compression ratio would be great for when i turbocharge it.![]()
I can remove some of the material from these washers to make them thinner if it is a worthwhile effort.
ssm200":16sp43vt said:The washers are right around 0.065 and the rockers don't touch the valves when they are closed. with these washers installed and the rocker assembly torqued, i can fit a 0.025 feeler gauge between the valve and the rocker. I have non-adjustable rockers, hydraulic lifters and hydraulic cam. I used bronze bearings and they are the thinnest washers i can find that have appropriate measurements.
ssm200":hlpw2t71 said:I put a straight edge across the valves and i cannot see any variation in the depth of the valves except one is a hair low in the cylinder.
On another note, i was checking valve lash as i was putting the rocker assembly back on and noticed that i could push the push rod end of the rocker down and it would spring back. Never noticed this before, just figured it was part of how the hydraulic lifters operate. Then i check the rest and only like 3 have any spring to them. It seems like this is a problem that cannot be overlooked. These are "dead" lifters, right?
Thoughts? The head has to come back off, doesn't it. And i can't reuse the head gasket can i. :arg: what about the head bolts, can i at least reuse them? they are ARP bolts. i've driven maybe 10 miles since i put the head back on.
Any advice on lifter selection?
am i closer to the end than the beginning?![]()
