Bubba,
1. I don't believe i have a vacuum leak, but will check again.
2. They are fixed rockers, no valve adjustment.
3. No idea what timing set i used. I may have a receipt somewhere, i save everything.
4. I checked vacuum twice every time, on the spark control port and then manifold vacuum, through the unused intake temp sensor. i think that is what it was for. it's a 1/2" pipe thread just like the coolant temp sensor bung. I use it for the PCV and the transmission vacuum.
5. I would love to add more base timing, as i think that's what it wants. I was nearly in the green zone on the vacuum gauge, i think around 14-15"
6. I read up on selecting a power valve and it seems i need to get everything else sorted out to get a good vacuum reading before i can select the proper power valve. Is this accurate?
9. So i could be getting weird stuff from the hot air tube being...well...gone. If i use the brake line method, i wrap the other end around one of the header tubes and leave it open? Does it draw it's own air? The choke blade currently opens completely with a little resistance, but that could be from the warm air around the motor when it's parked. Then while driving i suppose it could close some and i would never know. Stupid choke. I have some work to do here. Since i removed the choke pull down diaphram, will i be able to get the choke working properly? or should i consider scrapping the thing and going with a manual choke?
I will keep tuning, probably post more tomorrow or sunday. Thanks again.
but this is why I tried to give you a step by step program order of doing things and focusing also those that were either of a no cost or or low cost too. IE the Basic tune up, using the washers to see if it raised your compression and raising the idle vacuum etc. As you now know there are lots of areas that need to be checked when doing custom tuning of parts that weren't designed to be used together on your engine, as well as having a mechanical issue or two, i.e. The compression balance and not knowing how the cam was installed. You probally will need to also check the accelerator pump linkage adjustment to see if the pump shot is timed right and or has a long enough duration too to carry the engine through until the RPM's come up. Good luck
