After a long period of a few years of my car running mostly good, lately has been one thing after another. I've got a 200 with a large bore Holley 1940 carb, 1968 distributor with Pertronix and 12v coil. My problems lately have been thus:
When I try to accelerate after an idle, the car sputters, bogs down, and sometimes dies. Low RPMs it dies, but at higher RPMs, it is okay. Yesterday driving to work it was real bad and I stalled a few times coming off of lights. I opened up the hood at work, fiddled a few spark plug wires, and at lunch tested it out (even on the freeway) and all seemed great. But when I went to go home, the stumbling problem happened again, now even worse than before.
Last night, I rebuilt the carburetor just to see if the accelerator pump was bad. I also replaced the inline fuel filter. I put it back on, things seemed better, yet on the way to work again this morning, same thing again.
Here are some things that I have noticed recently: After a hot day, the car is very hard to start a few hours later after the engine has cooled. I crank and crank and crank as if the fuel bowl is out of gas. When I do get it started, It usually dies again the first time I try to accelerate, but after that it is okay. But I don't have this problem if I just run into a store. I only have this problem after the car has sit for awhile. The spark plug wires and distributor cap and rotor are new.
I'm thinking fuel pump going bad. Thoughts? I could also pull the plugs and wires again and see if I can find one that is not right...
