Juggernaught
You can do that- using the taper rollers for thrust and the rollers in the center mains. But why? Frictional loses would be reduced, but enough to justify the expense? Certainly not on a log head six.
Remember that if you can think of it, someone else probably has also, and if it's not being done, there' usually a reason (for this, the expense of roller bearings and needing to shim the bearing cine for the taper roller to get correct thrust come to mind.
Don't want to stifle creative thinking, but if you can think of something, you must also think of why it might not work, why aren't people doing it today.
There are lots of reasons roller element cranks aren't widely used on 4 stroke engines, money being the biggest. But you need to determine if the costs of a proposal outweigh the benefits. The aforementioned Suzuki motors probably maintained roller cranks because Suzuki had built up crank making capacity from their 2 stroke operations when they started building four strokes. I can make it myself or pay someone- if I have excess machine capacity, even if my built up crank costs more than a single piece, it may be economic becuase my machine utilization is up.
Lots of reasons. Usually driven by economics, not by the intrinsic value of the design.
When Suzuki got into 4 strokes deeply, they switched to single piece cranks. As volume increased, they could make payback on new equipment.
Simple economics
