All Small Six Distributer rotating backwards
deefduke
I am restoring a 1969 mustang with a inline 6 250. I rebuilt the motor. My manual says the distributer is supposed to rotate counter clockwise but it is rotating clockwise. I am turning the engine over clockwise looking at it from the front which is what the starter does. What is my problem??
Top Poster
Staff member
Supporter 2021
Supporter 2019
REDLINE 10K
Hi deefduke and welcome to the Ford Six forum! I would say that the reason is because you are looking at it from the front of the car facing the engine instead of from behind the engine like how the manual is describing it. In that case (standing in front of it) the Distribitor will turn clockwise this rotation is controlled by the camshaft gear, crankshaft gear, and timing chain and can't be easily changed short of having the camshaft ground backwards to make a reverse rotation engine.
Do you have the Distribitor rotor set in the right location for firing the #1 cylinder at 6 degrees BTDC? Also are the spark plug wires in the correct firing order of 1, 5, 3, 6, 2, 4, ?
In this link is a diagram showing the Ford 250 Six's correct firing order, rotor postion for the #1, and also shows the correct rotation of the rotor. http://mainemustang.com/mustang-info/65-66-mustang-tune-up-info
Good luck on your 1969 Mustang 250 six.
deefduke
I checked several other sources and they all said the distributer should rotate counter-clockwise. Could the direction be changed with a different gear on the distributor or possibly did I get a wrong camshaft?
Top Poster
Staff member
Supporter 2021
Supporter 2019
REDLINE 10K
So the answer is no to both of your questions, if you look at your camshaft the Distribitor gear is cast as par of the camshaft and the gear is machined with its teeth going in one direction. The Distribtor gear has to has to mesh into the camshaft gear a different gear isn't going to fit and mesh into the cam gear and they aren't made anyway. The engines crankshaft would need to turn in reverse to turn the distributor counter clockwise. And the camshaft would also have to be specially ground so the cam lobes open and closed the valves opposite of a stock 250 six for the engine would run in the oposite direction. Very few engines are made to operate this way one Application is for one engine used in a twin engine boat however I haven't heard of any of them using a pair of 250 Six'es in them. Next the starter motors electrical coils would need to be rewound in the oposite direction in order for the starter to turn and start the engine in tgat reverse direction. Then the transmission gears would also be turning in the wrong direction giving you as an example for a simple three speed trans, three reverse gears and only one forward gear and lastly the rear axel would be turning in the wrong direction to. As you can see it would be far to many things that would need to be custom made.
Did you happen to look at that above link? So again the real reason for your confusion is that you are standing at the front of the car facing the engine, the way automotive technical things have always been described on cars and trucks is from someone standing at the rear of the car facing toward the front or else also by when you are setting behind the steering wheel facing forward and still behind the engine. So remember that as soon as your standing in front of the car facing the engine then everthing is now in reseverse. Best of luck
B RON CO
1K+
Supporter 2021
Supporter 2018
Hi, X2. The rotor turns clockwise on our Ford six engines. Just google Ford 200 firing order. Good luck
wsa111
Distributor Recurving.
Staff member
Approved Vendor
Supporter 2018
The Ford V8 is CCW. The early 289-302 had a firing order of 1-5-4-2-6-3-7-8.
This was changed later because of torsional load on the crankshaft.
For you V8 guys if you replace the camshaft in the early engines use the later cam for the later firing order.
1-3-7-2-6-5-4-8.
As Bubba said the small six distributor shaft rotates CW 1-5-3-6-2-4.
