The faq in the tech section says that the white wire from the ford module when engaged will retard advance a couple degress. My interest, and I'm proby way off base, is if I could somehow use this with my A/C. That the white wire would be engaged except when the compressor cut's on then the advance would increase the couple degrees and offset the load.
don
don
