I have a '67 Futura. I've resently put the DSII in with the stock modulator and it had been running fine for about a half a tank of gas. The other day I stomped on it to merge and a little ways down the road it starts missing. Long story short, later that night I was looking under the hood and I could see an arch between the battery (+) side of the coil terminal to the center area.... near where the coil to distributor wire plugs in.
I had a new coil from another 200 and put it in and this time it looked like it was arching from the (-) or tach side. Here is what's running through my head about causes and solutions:
1) Do I need a different coil for the solid state ignition?
2) The red wire from the modulator is attached to the battery (+) of the coil. I noticed on the wiring diagram from the tech article that it should be wired before the ballast wire. Should I rewire it?
3) Did the stock ignition come with a ballast resistor?
4) If I've wired it incorrectly, have I ruined the modulator?
An interesting side note. After I first installed the new ignition, I couldn't get my car to crank. I tried using one of the portable batteries, it turned over a little better, but still no luck. After tearing it all apart and putting it all back together, I put in a fresher and bigger battery and Varoom, it starts up. I guess the newer ignition needed a little more juice to make it work.
Thanks for any ideas. Still no deiseling! Must've needed the higher octane fuel.
-MikeD
-MikeD
