65fback
So after my 'adventures' installing the DSII distributor I've only had bits of time here and there to get the wiring done. That's now complete. The car won't start. It'll turn over but I'm not getting it to start. I've rechecked the wiring a couple of times. I've also verified I get 12V at the + terminal on the coil when in the ignition is in the run position as well as in the start position. I also tried rotating the distributor a bit to adjust timing with no success.
Full list of wiring changes I made:
* ran green wire from 4 plug on ignition module to negative (-) terminal on ignition coil
* ran white wire from the 2 plug connector on ignition module to the S terminal on the solenoid
* disconnected the brown wire from the I terminal on the starter solenoid
* ran red wire from the 2 plug connector on ignition module to the positive (+) terminal on the ignition coil
* cut the pink resistor wire from the ignition
* ran a wire from the run position of the ignition to the positive (+) terminal on the ignition coil
The module is a replacement module for the DSII ignition module. It's got the blue sealing block setup. The coil is a 12V coil 'for electronic systems'.
Any advice of what to check next?
