Are you referring to the "dot" on the cam gear?
If so, there should be a corresponding "dot" on the crank gear as well.
Usually the proper installation is for the 2 "dots" (or whatever the mark is) to be in close alignment between the 2 gears when the #1 piston is at TDC of the compression stroke.
So, if the crank is at TDC #1, the dot on the crank gear and the dot on the cam gear should be at their closest point directly in line with each other. (You should be able to take a ruler and hold it on the c-line of the crank and c-line of the cam, and have it pass right over both dots. The 4 points should be in perfect alignment at TDC #1).
Now, this is correct for top of the compression stroke, but if you are at TDC and the cam gear is 180-degrees around (furthest from the crank), then you are at TDC of exhaust stroke.
Again, I use the word "usually" on purpose. Check with the manufacturer of the timing chain set and verify what the correct timing mark alignment is just to be sure.
Also, if you only crank part way and it stops, that sounds to me like you have pistons hitting valves right now. Stop right there and don't try to force it any further, or you will certainly be looking at more expensive repairs. Those parts were never meant to meet...
