Well… According to my math, on my engine, at straight up on the timing chain (dot 2 dot), the Clay Smith cam is advanced by 4 degrees. I’ve checked the intake lobe and it should get a reading of 105 degrees but I get a reading of 100.5 degrees.
My numbers are as follows:
Top of Intake Lobe cranked back 50/1000: 52
Top of Intake Lobe cranked forward 50/1000: 149
(52 + 149) / 2 = 100.5 INT
Advertised numbers are 105 so my number is 4.5 degrees advanced. I’ve checked about half a dozen times and checked TDC several times to make certain. Every time I get the same numbers.
My cam chain has a multi slotted crank gear so I can advance/retard the cam 2, 4, 6, 8 degrees. I think I’ll retard it 4 degrees and recheck my numbers.
View attachment 22927View attachment 22928View attachment 22929
