country fried 6
i think someone said it was hard to get info on new diesel turbos. well, i happen to have one sitting here on my bench, it has to go back for a core but i thought i would post some info if might help someone. it's not mine to use or sell, and i cannot disassemble it.
its a Garret VNT from an '07 Duramax LBZ, it has M48 cast into the tubine housing. turbine A/R is .90, compressor A/R is .58. it has dual inlets on the exhaust housing that face straight back. could to a usefull configuration if running EFI manifolds with J-pipes on a 300?
Garret P/N 8980385680
new one has P/N 8980117353
the difference in part numbers may only be that the new one is a reman part.
i could maybe get other measurments if you get back to me before the end of the work day today. i don't know a whole lot about turbos, i olny work with them in factory GM applications, so be spicific if you want measurements.
	 Maybe someone will try it though.
