Looking for some help with a Duraspark install. Have a engine just back from the shop and the old dist was already out when it came back. Shop has #1 cylinder at TDC and the timing marks on the crank are all aligned. I have a new CI duraspark and I was thinking it would just drop in place but so far no luck. The new Dist is very snug but I think I can get it to go down but I do not want to force it. I've read that the rotor needs to be pointed at the # 1 wire and as there are no wires I am using the #1 spark plug as reference. I cannot get the Dist to fall in unless I move the rotor towards the front of the engine. When I do this the rotor starts to turn counter clockwise slightly as the Dist moves down. At this point the Dist again is snug and still has to go down about 1 inch but it feels like I could force/ push it down.
Trying to figure out if I am on the right track here.
Also, When they say the rotor points to #1, which end of the rotor. I assume it is the end with the contact, the more pointed end but different internet blogs show pictures of the reverse.
Many thanks
Many thanks
