Did DII conversion in september. Car ran ok until december, always had problems starting the car. Then found out I never eliminated pink wire from ignition. When I changed wire I did not disconnect battery first and got a spark from the pigtail on the ignition switch when I plugged in the direct line from the ballist. Since then I get no engine turn over, all it does now is buzz at the solenoid when I turn the key. I have replaced distributor, solenoid, ignition switch, starter and even tried putting old pink wire back in, nothing works. Tried in park and neutral, no difference. Advance is set at 13 degrees, plugs gapped a .55
Any suggestions?
Car is a 66 mustang, inline 6, 200ci, automatic C4 tranny, weber 32/36 dual carb conversion with electric choke.
Any suggestions?
