We are going to install a Duraspark ll distributor in our 1965 Mustang. Where is the best place to find a switched 12V power source? Is there a good place in the engine compartment? I checked the "+" wire to the coil and the "I" terminal on the starter solenoid but both these only have a little more than 6V. Does this sound correct? If yes, is there a resistor somewhere (it wasn't obvious so I'm sure I just don't know where to look)? I plan to use the Ford control module and follow the Forum's instructions.
Also, David is always sure to point out that the vacuum control valve on the Autolite carburetor must be removed and plugged. Does anyone know what threads the plug should have?
Thanks for your help.
Tom
Tom
