Guys, I cant seem to get my this duraspark setup to work. I am using a stock module. The white wire off the box is going back to "s' on the solonoid. Green from the box goes to "-" on the coil. The other 3 go from the box to the dizzy. The red wire is tapped in 4" from the ignition switch "to the red wire coming off the switch". From there it goes to "+" on the coil then to the box.
When cranking and both leads on + and - on the coil I get approx 6v. When cranking and going from + on the coil to ground, I get 10-11V.
Still I have no spark. Any help would be great. I am literally pulling out my hair...........
