80Stang
This is a topic that applies to all engines and puzzles me in a spesific way, so it applies to our sixes as well. I'm looking for some more information from you gurus for my own work and at the same time hope this thread comes somewhat useful to more people. Maybe you can catch my mind-flow from this:
Pre-question: How do you calculate dynamic CR?
Simple...yes there are calculators in the net and so on. I personally use the one on the Keith Black website. But...
Core question #1: How do you determine when pressure starts to develop in the chamber?
Yes yes, take the intake valve closure point and use the calculator. Ahs, not so simple. The pressure starts to develop before the intake is closed, and usually you consider the intake closed in means of flow before it actually is closed.
Remember the pre-question.
ok, we can calculate the pressure development after the intake fully closed, but shouldn't we also consider how much of it developed before the intake closed?
Core question #2: How to determine how much pressure developed before the intake totally closed?
At least you'll need to know the flow characteristics from the chamber/bore to the intake manifold and maybe some other things to determine this, like any pulses from the intake manifold from other cylinders etc...
I'm a simple man and not at all genius in this field or in mathmatics or flow technology. Still, I do build engines for my customers, plan and test different combinations, learning from my previous experiences to build better ones in the future. There is a lot going on with planning CR, cams, timing, displacement effect on cam choices/rev ranges/torque etc etc. Basically I use the KB calculator with a certain method determining the intake closure point for the calculator for dynamic CR, thus my build-ups are planned the same way and that way comparable to each other. Then I aim the dynamic CR to certain range using that calculator, knowing exactly how the previous combinations worked (as they are dynoed in an engine dyno) and learning from that. So far the combos have been good and they are getting better, but I'm very eager to learn more.
Roller cams are much more exact in the way they open and close the valves. They are much sharper, of course. I can pretty reliably use the intake closure value at .006" lift with the calculator, and get consistent calculations between cam manufactureres and different cam grinds. With flat tappet cams the cam closes usually pretty sharply to some point, and then seems to slowly close to the rest and any low lift measurement like .006" will give you very low dynamic CR. That is why the .050" lift value is given as that is more comparable between different types of cams.
