Early Bronco Headers
Explorer
Are there any options for Bronco specific 200ci headers? I've only found one vendor and I do like to shop.
Not a big clifford fan since 2001, but these headers fit very well, have a 3/8 flange, they are fully welded on the the face side and tacked on the outside, I had mine fully welded on the outside and then sent off to be ceramic coated, the engine bay in the bronco is known to be very warm, so my hood scoop has a 14 inch cooling fan under it to draw air out of the engine bay and not for hood clearance.
Thanks for the info. I'm going to call my local powder coater and see if they do ceramic coating. They're a pretty big company, might get lucky.
Maybe the new Classic Inline headers will fit. I am thinking that with the new design you could bend the two down pipes so they tuck around the frame and starter- just a thought, but it should be easier to modify than a full length 6-1 design.
Someone in the Bronco section of this forum did modify a set of headers to fit.
