Hello all. I've started porting my EFI head and noticed something interesting. In the top left corner of every intake port there is a "bulge" of carbon deposit. I checked out the lower intake manifold and this is the exact spot the fuel injector sits above. The Fel-Pro manifold gasket set I bought has a double steel faced gasket that's one piece for the exhaust AND intake manifolds, but the oval intake ports actually cover this "bulge" when you line it up on the side of the head. My question is, should I carve this bulge out of the head with the die grinder and modify the gasket to fit?
Btw, notice where I started grinding down around exhaust port 6 (right)around the air injector bung. Compare it to exhaust port five (left).[/img]
