Engine back together = running
Crosley
I have the 200 CID engine running in my 1962 Falcon again.
I had the head off for modifications for a direct bolt 2 barrel Holley carb. I used a 4412 Holley carb , 500 cfm rated.
I did some quick testing of the engine response in my driveway. the engine did stumble lightly as I rolled on the throttle from a stop, it still spun the tires a little on the concrete.
I hope to test n tune at the drag strip soon to dial in this new combo. I still need to work over the dizzy advance curve. The dizzy in the engine is stone stock at the moment
Tony, i bet your wife likes the rubber railroad tracks on your clean driveway.
Otherwise congradulations on gettting your hot rod back together.
Your times before were awsome, good luck with your new found HP. Bill
