Beers1
I"m trying to identify an engine in my daughters 1972 Mercury Comet. We bought the car last year and ran it for a little while before noticing that it has started to burn oil. I completed a compression test and the results all came back within 10% of each other at about 120 PSI, so I figured its not the rings. I looked at the plugs and identified where we are having the problem; valves. Since the compression is low and we need to pull the head I figured it would be a good time to rebuild the engine and freshen it up anyway. The previous owner had it for about six years and stated that he didn't know if it had ever been rebuilt. I just want to build it as a reliable little car for my daughter.
The block has the following cast numbers: D8 BE 6015-GE
The head has the following cast numbers: D8 BE 6080 BA
The exhaust manifold has the following cast numbers: C8 DE 9430 A
The information I have found indicates that this would be a 1978 engine, correct? It would appear that the exhaust manifold came off a 66; are they interchangeable?
Any help would be appreciated, and thanks in advance.
Rich
Rich
