If I degree a small six cam and it is right on, I assume that I made a mistake, and check again and find I did.
A compression test would indicate erroneous valve timing or potential valve sealing problem, if the rings are good.Today I tried some things. I re-gapped the plugs to 0.035” as Frank suggested with no real joy. I did check the rear valve cover breather for vacuum signal and there was a little, I’m hesitant to call it vacuum, but it would draw a piece of paper towards it- not very strong at all. The brass fittings in the adapter have an ID of ~0.25” at most and in some areas it appears less.
Everything I try seems to have no effect or the engine runs worse, so I had to step away and just crack a beer.
I again checked for vacuum leaks with propane and found none. Putting propane into the carb would pick up a little RPM, but not smooth out the engine. The additional fuel was read by the AFR meter.
The engine just has a miserable idle and what sounds like a constant misfire well into the RPM range, so I can’t help thinking there is some underlying issue here, but don’t know what it is. All components seem to function properly, but the engine is not happy. Ignition?, thinking of substituting a TFI coil on the shelf.
Another thought I have is when I assembled the engine, I degreed the assumed stock camshaft to specs in the Falcon Performance Handbook. It was off about 12 degrees with the assumed stock timing chain set the engine came with and I installed the CI adjustable double roller set to match the timing events in the handbook. I’ve degreed camshafts before, but the thought that I F’d this up somehow sticks in the back of my head.
I guess I failed to mention earlier that I bought this “rebuilt” engine at an auction and went through it when I got it home. So all the parts are new, but I didn’t purchase them.
I owned an early Mustang quite some time ago that had a rebuilt 200, and it idled so smoothly you could set a wine glass on the air cleaner. I realize this thread has gone from a simple question of cylinder heads to where it is now, but I do appreciate the help.
I could try a compression test to see if the engine has too much cylinder pressure or low pressure, or maybe it's just right.
What I did when the engine was assembled, was match the timing events published in the Falcon Handbook for a stock cam. It's within a few degrees. The camshaft was in the engine when I purchased it and brand new, like the rest of the engine, but specs are unknown. LIft was comparable to a stock cam- I don't know the duration profile but guess it's likely stock also.
Would a few degrees +/- make the engine idle roughly? It's more of a misfire than the rough idle of a lumpy cam. It makes good power for its size up to 4000 RPM w/2bbl.
Yes ^^ . And a manifold vacuum reading would be helpful in diagnosis. both timing and valve sealing.For a misfire, I would look at my timing to make sure my initial advance isn’t too much.
Again- this would be quickly verified by a compression test.This is unlikely but the other thing I’d look at is my valvetrain to make sure I have enough clearance when the valves are supposed to be closed. I’m not sure if your valvetrain is adjustable;
Possibly lumpy if it's retarded, but a misfire- no.Would a few degrees +/- make the engine idle roughly? It's more of a misfire than the rough idle of a lumpy cam.
Hey Otto, glad to get this report. And glad to solve the idle issue. Yes 30+ degrees of idle timing is nothing short of unacceptable. You're 'tween a rock and hard place.The marine carburetors typically don't feature ported vacuum, so the only option is manifold vacuum. The DSll distributor is connected to the manifold.
Frank, please elaborate on this; is it possible to adjust it so there is minimal advance at idle but near the total amount the engine would be happy with at cruising speed? Or is this just wishful thinking?Many vacuum advance canisters are adjustable. 22* of advance may be ok for that engine, it's too much for a 300.
This, ^^ unfortunately. The total advance may be adjustable. That's not the issue, when it's active is.Or is this just wishful thinking?
Good point Frank, I’ve thought of this myself. I dug out other 2G carbs on the shelf that do have ported vacuum ports to see how this was facilitated.Have you examined the carb bore closely? Wonder if there is a port and passage for ported cast in, just plugged. It would be a hole or small slot just above the throttle blade on the upper leading edge, with the throttle closed on base idle.
Good research!! I was going to dig one out myself to look, but my wife's 100% from-scratch pizza took precedent. The red arrow is pointing at the distributor vacuum source. If the marine unit has those portholes and it can be tracked to a blank or plug on the exterior, you'll be in business. Only needs to be in one barrel. All it does is let the closed throttle block manifold vacuum. Distributor vacuum is 0 until the edge of the throttle gets high enough to allow air to pass over the port holes, then the distributor sees intake manifold vacuum. Jumps from 0"-18" or whatever the intake vac is at that moment, instantly, not gradually. Light load needs the increased advance, idle needs none. Ported carburetor vacuum works precisely. Hope you can unleash it in the Marine unit.Good point Frank, I’ve thought of this myself. I dug out other 2G carbs on the shelf that do have ported vacuum ports to see how this was facilitated.
With the throttle blades closed, the idle mixture holes are visible.
Cracking the blades a little, other very small holes are uncovered. You can see a trio of small holes in both barrels, and a couple of slightly larger holes in one barrel. I traced these to what appears to be a vacuum hose port. On the carburetor base there is a plug that seems to coincide with these holes. I see a similar plug on the van’s carb. Tomorrow I’ll take that one apart and see if that is the case with the Mercarb.
It’s interesting that the ported vacuum port only seems to be located in one of the carb’s throats. It might be possible to drill an insanely small hole with incredible precision and land the hole just above the throttle blade. It would be great to just make ported vacuum happen!
x
The base is cast iron.If that base is cast iron - and not alloy, you will have a hard time drilling with a small drill bit.
Maybe drill with a 1/8" bit but not all the way thru and do the last 40thou with your small drill bit
...measure depth twice , drill once....
