MercuryMarc
I have put my Holley 1940 maual choke carb back on my car (still rebuilding my HW 5200)- I converted it to auto choke using a spare electric choke spring. It runs great- starts well cold, choke plate and fast idle cam full open after several minutes. But after 20 minutes of driving, the car idles rough, stumbles, and stalls when idling. I reset the idle mixture to get the max RPM and set the idle speed screw a little higher then the recommended 700 rpm idle speed. The problem seems to be worse when it is very hot. I have not had this particular problem before with this carb or my 5200. Any suggestions?
Thanks!
Thanks!
