Hello Everyone, I have a semi heavily built 1965 dated 200CI block. My modifications to the engine are as listed
Holley 2bbl 350 cfm carb
Clay smith H274 8 b cam
DUI elec ignition
Summit racing headers
And a 10:1 compression ratio.
After around 15 minutes of driving the car prior to reaching operating temperature in the higher RPM band the engine will cut and will not want to start for around 3 minutes after cutting out. I have theories of possible over heating , lack of fuel flow (still on mechanical fuel pump) or loss or oil pressure. I do not have a working engine temp or oil pressure guage installed however while idling and light pulls a handheld oil pressure guage reads around 45psi. Any guesses.
DUI elec ignition
